Predict My 1/4 time with my set-up.
Essential_DSM
48
Apr 9, 2008
St.Paul, Minnesota
SET-UP:
Buscher 20g turbo (External Set-UP)
Full 3" Buscher Racing Exhaust system
Buscher FMIC Kit
Full Weight
3" MAF Sensor
3" MAF T Translator
Crower 272's I/E
2 X 255 Walbro's
Fuel Pressure Regualtor
PTE 1000 CC Injectors
Tunning Tools:
AEM WideBand
DSM LINK
E85 Fuel
Boost at 25psi
Stock Suspension
Seeing as I dont see any logs or charts, im guessing your tune sucks and you will blow your engine halfway down the track and run a 13.6.
Thats just my guess, this thread will probably be locked soon but good luck.
GO TO THE TRACK!
Hahaha... If you've ever heard of Desolateboosted here on DSMTUNERS. Did 11's on a street tune with similar set-up. A good buddy of mine. Stock internals and tuned himself. And why would I run my car without a tune.....? He's tuning it for me.
This will soon be locked as it is bench racing. I predict you run a .001 with a 1,674,434 MPH.
Wait for this POST next month... I'll keep you two updated on 1/4 mile time and hopefully with a video.
Good go to the track and see what she does, if you want a comparison than look at other peoples profiles with the same set-up. Their are soo many differences from each car to another, from the day it was built. No one can tell you what to expect. Also their are many other factors, from driving skill, weight, altitude, track temperature, air temperature, etc...
This is so bench racing.... Guess someone hasn't read the rules...:notgood:
Probably into the low 12's high 11's area. I understand you are just wondering about potential of your setup. It sucks that you can't ask where a setup will take you quarter mile wise before you buy it(assuming you have it tuned correctly and you achieve the normal power levels and such of the setup in question), without it being dubbed bench racing. People are so closed minded and repeat everything else other board members say. Bench racing in my opinion is when you are asking if you'll beat another car in a race with a certain setup. I'm sorry for venting but this just irritates the heck out of me. Rant over.
Once again I will re-state what I said before. Every set-up is different, in some way or another. Every car is different from the day it left the factory. 25PSi on one motor is different from 25PSi on another. If their was hard data posted, aka timing curves, dyno #'s, race weight, etc, we could give a lot more accurate estimate.
Their are plenty of topics on different turbos and set-ups that you can search and find. Now if the original poster had stated, is this a good set-up, what else do I need. He would get more information than just strictly stating this is what I have/want, this is what I'm gonna do, what should I expect.
He could see anything from high 10's to 20's with that set-up. Driving, altitude, temperature, etc, their are just way to many factors to give an estimate. Get the parts installed, tuned, go to the track, then come back with hard data. Logs, dyno #'s, timeslips etc... Then ask is this a reasonable time, what should I do different, etc...
Well im going to guess he wont make it to the track, if he is running a stock clutch. You need to finish your profile so if you as a question like that then we will have a better idea where you are coming from. I don't even know if your cars automatic or not.
First time I took my car down to the track with a bunch of mods, I ran a 14.7 @ 94mph. This was with a setup that did 12.8 @ 109 later the same day.
Anyone can make a car go fast, you need to drive it. Go to the track, and stop bench racing. Be happy that you don't break as you DO own a DSM.
