transmisson questions
1gtalonlove
May 8, 2013
traverse city, Michigan
ok guys a just had my 5 speed 91 awd trans rebuilt and now I put it in the car it shifts in every gear but first? I took the linkage off and still doesn't seem like it wants to go into 1st. any help would be appreciated.
It will not go in at all but every other gear it will. But my shifter is way different than before 3/4 gear is a little to the right of where it should be. Also I have to strong arm it into 5th and reverse also second? If you have any ideas let me know please.
Take the cables off and shift it by hand at the transmission. If it goes you have a problem with the shifter cables and likely the clutch as well. I suspect clutch as you're having to strong arm a gear.
Tell us what else what changed besides the transmission.
Nothing else that I changed would effect the transmission. I might not have blead the clutch all the way. I will definitely check that out and go from there. Is there a post about shift linkage?
Now to think of it I did take the shift linkage off and it went to all gears fine so I most likely have to adjust that. I am just not to sure how to correctly
