1G Transmission Spring Pin
thejollyrancher
307
13
Mar 31, 2012
calgary, AB, Canada
The manual says i need tool MD998019, which i do not have. Is there any way to remove that pin without a fancy mitsu tool?
Use a 5/16" roll pin punch to start it from the inside, going outwards with the transmission shifted into reverse to give some additional clearance. Then use a vise grips and work the roll pin out. Easy.
