Transmission removal time?? How long?
96bmwm3
39
Mar 15, 2004
Sugar Land, Texas
HOw long does it take, roughly, to get the tranny out of a 1g with everything still installed? Just wondering how much time to alot.
If it is your car judjing by the items you have allready replaced and should not give you a problem to remove. I will say 1 to 2 hours to get it out, an afternoon for a clutch job. If you get out all the tools you will need first (not going back and forth to tool box constantly) maybe less time. Depends on the problems you encounter along the way mostly. If the car is taken apart and put back together a lot it tends to go more smoothly.
With a lift I can get mine out in close to an hour or less. Maybe I should go for the speed record next time.LOL
Long as electrical is unhooked, vac lines, ect, you can pull the engine/trans in under an hour, I pulled mine in 45 minutes but I had a 4 point lift, and a hydrolic engine lift at my disposal.
Dustin
I used a jack and jack stands in my garage and had it out in about an hour, hour and a half. Taking it out is the easy part, putting it back in is more difficult.
