transmission problems
kendrick
Oct 26, 2014
gainesville, Georgia
Alright so I need some help I got my motor and all installed hooked up the new shift assembly now when I try to put it in first or second it won't go all the way to the left it's like something's blocking it but when I take the linkage off the tranny it goes all the way to the left could someone tell me what the problem could possibly be do I need a new tranny of what I checked to make sure nothing was in the way of the linkages an it still does it an it's a 2g gst 5 speed
I assume it's not bumping into the lower radiator hose. Does the Select Lever cable have enough throw to get into 1st/2nd? Have someone shift while you watch at the tranny. Then disconnect cables from tranny and hand shift the levers to see what throw you need.
