transmission problems
twitch49k
Dec 1, 2008
San Jacinto, California
ok well first it started grinding in 2nd gear so i started going from 1st to 3rd for a couple days and then while i was driving all off my gears started grinding so i pulled over and tranny fluid was pouring out of my tranny. now obviously my tranny is messed up, but i was wondering if im going to have to replace the whole thing or possibly just fix whats wrong with it? if anyone can i help i would appreciate it
Make sure you axle is in the transmission and some how didn't pop out.
well the fluid isnt coming from the axle. and its not the drain plug. im not really sure what its leaking from tho. ill get underneath it right now so i can give more detail as to where the fluid was leaking from. maybe i could even take a pic. also i forgot to mention the car wont move. it just grinds
right on man. thanks. ill try to get some pics or at least some better info on where the fluid was leaking from by tonight. the car is at my buddies house so ill go over there in a few and check it out
here is a pic of where the fluid leaked from. it turned out being a hole that looks like something blew it out. it looks like its something that is bolted to the transmission and not the actual transmission itself. its on the opposite side of where the tranny flushes up and is bolted to the block
i know. im having a ard time adding it in the reply. how do i find the url of the pic? if you have an email address i can send it there
The best way to put pics up is upload them to photobucket then use a link button to add them to tuners.
here is a pic of where the fluid leaked from. it turned out being a hole that looks like something blew it out. it looks like its something that is bolted to the transmission and not the actual transmission itself. its on the opposite side of where the tranny flushes up and is bolted to the block http://C:\Users\J-DIZZLE\Pictures\2009_6_23
Lol. Doesn't work like this buddy, try photobucket. Or you can go down below to add files.
sorry it took so long to get this pic<a href="http://s851.photobucket.com/albums/ab79/TWITCH49K/?action=view&current=100_6044.jpg" target="_blank"><img src="http://i851.photobucket.com/albums/ab79/TWITCH49K/100_6044.jpg" border="0" alt="TRANNY"></a> up but here it is.
so what is that thing that is bolted to my tranny where the hole is? and can i just replace that? or will i need a whole new transmission?
HERE ARE A COUPLE MORE PICS. THERE IS A LOT OF METAL SHAVINGS EVERYWHERE AND THERE IS SOME KIND OF GEAR THAT FELL OUT WHEN I TOOK THE COVER OFF <a href="http://s851.photobucket.com/albums/ab79/TWITCH49K/?action=view&current=100_6057.jpg" target="_blank"><img src="http://i851.photobucket.com/albums/ab79/TWITCH49K/100_6057.jpg" border="0" alt="TRANNY 2"></a>
<a href="http://s851.photobucket.com/albums/ab79/TWITCH49K/?action=view&current=100_6061.jpg" target="_blank"><img src="http://i851.photobucket.com/albums/ab79/TWITCH49K/100_6061.jpg" border="0" alt="TRANNY 3"></a>
