Transmission Or Clutch Problems?
versatilx1
229
5
Jun 18, 2005
oxnard, California
Yes i need help see what happen the other day i had ran out of hydraluic Fluid in my resevoir and i had of course couldnt put it into gear. I Stopped and put the fluid in and still for awhile it wasnt shifting right it would grind. then later it went in ok but i noticed when i try to quikshift in high rpms(6,000) it would grind going into second and third does this mean my clutch is bad,Main seal is no good, or just need to bleed the clutch? :barf:
If you were out of fluid, and refilled it without bleeding it, you definatly need to bleed it. Also, what made you lose the fluid in the first place? You may need to replace some seals or it'll just keep happening.
The main seal leaks but not that much just drops and i knew thats what it was but i apperciate the feedback also are you fimiliar with Mirc im trying to head up a Mirc Channel its like a big chatroom where all users online can get direct help please spread the word
