2G transmission fluid change 98 eclipse gs-t turbo
222deuce222
52
11
Mar 10, 2014
culpeper, Virginia
I have never done this before but does anyone know what the bolt that say "oil" is on the transmission? is that the fill plug and where is the drain plug? I looked on vfaq but my transmission bolts are not in the same place as they are pictured on the website. i am trying to change the fluid in the transmission and put redline mt90 in it. it is a manual 5 speed transmission. pics would help a lot LOL
I believe the fill plug is a 17mm and the drain is like 21, 22 or 24mm 6 point box end wrench or socket. If it hasn't been taken off for a while or ever it could be really tight, may need a breaker bar of some sort! Other than that I would fill It with this stuff! OEM Mitsubishi Trans Fluid – Jacks Transmissions LLC, but redline is great fluid as well and will be just fine!
Make sure that you use a 6 point socket on the drain and fill plugs, a 12 point can round the head off. The fill plugs can be very tight sometimes.
thanks everyone! from the looks of it the bolts have never been taking off. Would a impact wrench be safe to use to take the bolts off? I would use a torque wrench to put them back on.
Why anyone still guesses at this type of stuff is beyond me. http://www.dsmtuners.com/forums/articles-miscellaneous/437697-what-size-bolt-nut-stud-fastener-1g-version.html
Locations for the fill and drain varied between FWD and AWD models. The VFAQ only shows the AWD. See: http://www.dsmtuners.com/forums/newbie-forum/390417-does-anyone-know.html#post152507198
An impact would be overkill for these bolts. I would not recommend it but hey, it's your transmission.
