Transmission cables at transmission bracket
4gfun
Supporting VIP
2,012
56
Dec 10, 2007
Ask Me, Virginia
I did a clutch job a few months ago and have a question about mounting of the shift cables. I know that the cables are held down by cotter pins but I believe that there were supposed to be washers of some sort there too.
Does it make a difference whether or not the washers are there? If so, what kind of difference. Also how do the washers mount? Do they go between the cotter pin and the cables or under the cables?
Thanks
The washers are there from the factory so I'd say it's best to use them. They go on the side with the cotter pins, probably so the cable can move more easily and doesn't snag the pin or bend it or something.
