Transmission begins to slip after driving a while
hypebeastdizz
Sep 21, 2010
Virginia Beach, Virginia
I got the garbage 420a engine.. (Yes I know)
It was the only model of the eclipse I could afford..
But to get into it.. I have an automatic...
And when I start the car and it begins to shift...it shifts smoothly...no grinds or anything..
But after around 20/30 mins of continuous stop-n-go traffic and highway speeds..
It begins it slip...which kills my gas mileage..
I checked the tranny fluid..Its a redish-color...
I smelled it..and check for any grits in the fluid..
(Negitive on both)
Will getting a tranny flush help it? Or Make it worse?
Or is it better to change the fluid?
I bought the car in March of 2010.. The guy I bought it from his wife drove it..(which they had for 9 months prior me buying it)
It is very hard to diagnose auto transmission issues. Flushing it at this point is probably pointless.It could band aid for a while, or it could dislodge some crude and give it the final blow.
If it doesn't have burn smelling dark brown/black fluid, then the clutch packs probably aren't slipping. If its filled properly, then that leaves me thinking the front pump, or the solenoid that controls line pressure.
There is no burnt smell nor is the fluid black.
I've googled about non-turbo trannys and they said they don't use transmission bands which causes the slippage in most cases..
It also said how people get a mistaken tranny problems with the soliniod(spell check) pack gets clogged which makes the fluid get to thin thus causing it.
I just don't want to go to a shop and charge me an arm and a leg and find out my tranny is trashed..
My car only has 134,000 miles on it. Its a 95.
The thing is...
Do the additives work or they a waste of time?
Or just get it flushed to see if it works?
It SHOULD be fine, but if it hasn't been maintained properly, and theres any sludgey crap, it could block a solenoid, or passage way in the valve body and make more issues.
The service manual take ~70 pages to explain the checkout, and testing procedures.
Check TCU codes
I'm not positive if this applies to n/t 2gs or not. It doesn't specify... If theres a code you can pull, that would help tremendously.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
