Transmision GONE ? Clutch GONE?
racer
328
Aug 8, 2003
Hey guys,today I was waiting on red light for like 30 sec,when it turn green I hit the clut all the way to the flour as I always do and went to shift but what hapened was HRRRRRR and it didn't want to go into 1st then I reliced the clutch and pushed back again to the flour,tryed to shift again and this time was perfect.It shifted no problem.I didnt have problem after that,I stoped and go like 30 times,and all were with no problems.What could that be ? :confused: Plz help.
Nah, syncros could be fine but check ur clutch oil. Dsm's are hydraulicly assisted if ur low or it needs to be changed then add or change, then see if it does it anymore. I know when my fluid was low i had to pump the clutch to fully engage it so the gears wouldnt grind. Could be syncros too i guess but check the oil first.
yea,exactly,same thing here.Also if the car is moving with like let say 5mph and I try to shift to R it wont go in without HRRRRRR,never.
Also if the RPMs are higher then 4000 I can not shift from 2nd to 1st gear while the car is moving,it just wont go in until the RPMs drop to like 3000-3500.
Yep, mine did exactly the same thing, im like 98% done rebulding my tranny, hopefully i fixed it, we'll just have to see i guess.
