Trans Axle Seal W4A33
Your first mistake was goin to autozone man. The seals they sell are not what u wana use at least not what the stores around here stock. Go to an advance auto parts if you have one they stock national seals thats what u want. And there should be a number stamped on your factory seal if need be.
Sounds like you mayhave a wear groove on the axles. The lip on the seal can actually wear a groove in the steel. The proper way would be to replace the axle if there is unless u can find an axle saver seal which includes a seal and sleeve to go over wear groove.
