tranny upgrade questions
customgst
Sep 9, 2012
saginaw, Michigan
ok so i have to replace my clutch and figured id upgrade some stuff while its out. i was wondering what are some good flywheels i have been looking at a fadinza/ xtd clutch kit, any good? and i want to change the shift fork and pivot ball as well...is there any thing else i can upgrade while its out? its a 5 speed just so ya know...o and the shifter bushings will be done as well... any help or advice would be great
Contact Tim @ TMZ Performance, he will help you choose the right clutch setup and needed hardware. Depending on our setup and power goals, you will have to make a decision. If you will drive the car on the street, then my choice would be a Kevlar sprung disk. I would leave stock flywheel, just resurface it to proper specs. ACT flywheels are a good choice too. SS-Series pressure plate may have enough clamping force for your goals.
TMZ Performance
South bend ss pressure plate and kelvar sprung disc with street lite flywheel. I did it all in one punch while I had it out. OEM slave, master, fork, and bearing. Fell in love
OEM throw out bearing. do not use anything else. I used an ACT throw out bearing, didnt last 2000 miles on a 2600b pressure plate. I run an ACT 2600lb pressure plate, and 6 puck sprung disk. fidanza Al flywheel also. made 400 hp on it, and my local performance shop (maperformance) is recommending stick with it when i shoot for 600whp this spring. (any more power and ill have to go twin disk.)
i planned on using the oem throw out, i have read up alot... i was just wondering what other things i can upgrade while its out..i was looking at the xtd stage 4 clutch...and can anyone tell me the difference between a sprung and an un sprung disk? i have read it and i just cant seem to understand it...and whats a good fluid to run?
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
