Tranny to Engine Torque Specs
4gfun
Supporting VIP
2,012
56
Dec 10, 2007
Ask Me, Virginia
I have been searching this for a while now and googling it too. Does anyone know what the 1g torque specs are for the engine to transmission bolts? I have a pdf with torque specs but the numbers are all over the place and poorly worded.
Thank you
Likely my PDF and I do agree it isn't the best, but it does have a Table of Contents that should point you to the correct pages for the information. I'm thinking about going back through it to try something else, but we'll see. Please PM me if you have any suggestions.
Anyhow, the three bolts (Transaxle Mounting Bolts) threading into the engine block are M10 (or 10mm) diameter bolts and are to be torqued to 31-40 ft.-lbs. The one bolt threading into the transmission is a M8 (or 8mm) diameter bolt only requires 22-25 ft.-lbs.
I appreciate you taking the time to even create that pdf. I really do. Thanks for pointing me in the right direction.
  • Wanted 6 bolt NT water pipe
    • chrisman287
