Tranny fluid pennzoil synchromesh
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
This for my 99 GSX i am changing the tranny,t-case, and rear fluid, I got the the pennzoil synchromesh like everyone says to get but it doesnt say like 75w-85w or 75-90w or it doesnt matter, and can I use the pennzoil synchromesh in the rear as well
thanks
ok i searched a little and found it,LOL but the only thing i didnt find was how much fluid does the rear diff hold?
Do you have the Mitsu factory, haynes or chiltons manuals? It will say in those. I haven't recieved my service manuals yet or I would tell you. Sorry. :talon:
yea i checked both but they dont tell about how much to put in,i'll just buy extra i can always return it,thanks
Syncromesh is for the gear box. Put a GL5 in the transfer and rear end. Mobil1 gear oil is good, cheap and available all over.
I use it in the transfer and rear end, and also in the jet pumps on my SeaDoos.
little confused after searching, can i use the pennzoil synchromesh for t-case and rear diff, i found one person said yes and other no, can someone clear this up
thanks
cheap,LOL $8 a quart,but if ## saying not to use pennzoil synchromesh in tcase and rear diff then ok
I read this thread and now I'm worried. I've been running Pennzoil Synchromesh in my tranny, transfer case and rear diff for about a month now. Will it cause any damage to my transfer case and rear diff? Should I change it to a Mobil 1 Gear oil or another heavier fluid?
I run Pennzoil Syncromesh in the tranny, and Redline Heavy Shockproof in the transfer case and rear differential. I think it took 2 quarts of Shockproof for the T-case and rear diff. Its good stuff.
According to the Haynes Manual:
Transmission 2.0 Turbo - 2.4 quarts
Transfer case - 0.5 quarts
Rear Diff - 0.85 quarts
Manual transaxle lubricant type: API GL4 SAE 75W90 or 75W-85 gear lubricant
Transfer case: API GL4 SAE 75W-90 or 75W-85 hypoid gear lubricant
Rear Diff: API GL5 SAE 90, 85W90 or 80W90 gear lubricant.
What the heck is a hypoid gear lubricant?
http://www.dsmtuners.com/forums/showthread.php?t=181805 "The transfer case and transmission use the same oil. It's the rear end that uses gear lube, which is different."
Doesn't this mean that I only need to change the rear diff fluid to something like Mobil 1 80W90? And that Pennzoil Synchromesh would be okay for the transfer case? (since it uses the same fluid as the tranny?)
Well I ordered 2 quarts of Redline Heavy Shockproof Gearoil for the transfer case and rear diff. I'll change it when I get it.
i would use mobil gear oil in the t-case and rear just to be safe,some people will say it doesnt matter,but your talking 10-20 bucks to whatever at-case and rear diff cost..
  • For sale 1g Hatch cover
    Grey hatch cover
    • Anthony Hornback
  • For sale 1g Bumper lights
    Full set and an extra driver side.
    • Anthony Hornback
  • For sale 1g Torque Solutions Manual Front Motor Mount
    1G AWD Torque Solutions Manual Front Motor Mount
    • Anthony Hornback
  • Wanted 1g Headliner
    Looking for a 1G headliner with sunroof.
    • Anthony Hornback
  • For sale 4G63 MHI 20G Turbo ( Zero Miles, built by JW )
    MHI 20G Turbo $700 + shipping and paypal fees* built by Justin Whitesell * ZERO miles since...
