Tranny ? 6 bolt in 2g....
gsxrtalon
395
Apr 23, 2005
Harrison, Michigan
Ok guys my 7bolt motor just blew so I have a 6bolt lined up to put it in but I have a few ?'s first. My car is a fwd tsi and the motor is from an AWD, is this possible to swap for of all? I need to get a different flywheel right? What all is necessary for the swap? Thanks in advance :thumb:
thanks for the reply.
And the 6bolt flywheel will bolt up to my 2g tranny, right. And thats all I need as far as tranny needs, is the 6bolt flywheel? Thanks again :thumb: :talon:
flywheels bolt to the motor not the tranny. So yes your 6 bolt flywheel will bolt right up to a 6 bolt motor. You need the starter plate from your 2g. That is the plate that goes between the tranny and the motor and the starter bolts on to.
