Car Cannibal
- 691
- 168
- Jun 7, 2003
Chicago,
Illinois
1G, S90 74mm TB, factory TPS sensor, NO IAC.
TPS shows .10v in Haltech, it can calibrate the pedal etc. Car will run but the idle was a mess so first....
What's the volts supposed to be, .10v normal?
Factory is like .48 etc odor and like 5V WOT.
Haltech is showing .10v idle and like 1.9v WOT.
The scaling is different so it looks like I'm close.
Is there a way to scale it in Haltech to 5v?
I can try this before tuner comes back.
Issue...
When I move the TPS, I can get down to like .007v so it's showing a range. I left it back at .10v.
The S90 TB is very sensitive to blade screw adjustments, idle was like 675rpm, then flew to 2500rpm after maybe a 1/2 turn or more.
Need some help here, appreciate it as I've had a frustrating year with the Talon since a huge issue with a big name IL DSM shop tuner smoked my turbo and head gasket on the dyno and handed me the keys. I've got maybe 20 miles since Sept 2023 on the car, unreal.
Remote Haltech tuner guy is cool and popped in today, Fathers Day, for 45 minutes to help me get things cleaned up but it's been a rough go after OHM harness and initial tuner being a newb.
I want to make sure I have TPS Haltech volt info and can get the car driving in the 2nd session later in a June.
Thanks
Issue...
Thanks
