TPS Questions...
Y2kzx12r
Jul 10, 2004
Portland, Oregon
When the gas pedal is pressed the TPS readout on the laptop should also show a change of value...correct?
And if the TPS is bad, would it cause major bogging or stuttering when trying to even move the car at all?
I was having problems with mine, car was bucking and hesitating, cel was on/off intermittently, just changed it and adjusted it and now alls well
Thanx for the info, I just sent the ECU out for a diagnostic just to eliminate that from the mix...only cost me a gallon of my homemade salsa haha...as long as it checks ok that is, heheheh...if not...$200-399 to get it reworked...
I have a Bushur Racing FPR getting ordered this Monday...and have a 1G Fuel Rail incoming (from a 91-94 Model, forget which hehehe)...as I hate fighting the stock regulator, makes it near impossible to get fuel adjusted...
So, after I get the PUTER back and the FPR/1G Fuel Rail installed, I will be looking at a TPS if the problem is still persisting hehe...
Will update once I get all fixed ...thanx again...
Scooter
