Tps question
SmashingDsm
71
Jun 12, 2010
palmdale, California
Hey whats up guys I have couple issues first one I had a problem with my tps I fixed it on my Dsm link but it's at .75 off gas pedal reading 1-2% and open is 5.00v reading 100% is the 1-2% and issue I should try fixing or just leave it alone ? Second when it's on idle at 1300 rpms when I put it on gear it goes all the way to 700-800 rpms what could be the issue ? Oh and its auto transmission :) would appreciate the help thanks :)
Sounds like you need to adjust your TPS should be at .63 volts which you can log with link without the car running and adjust. As for the 1-2% at idle you need to adjust through link also make sure that your throttle plate is all the way closed seems that your 1300 RPM idle is a bit high.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
