torque specs for 2.3 stroker Afap!
dawid4444
233
Feb 16, 2009
Chicago, Illinois
Hey guys.
Im building a 2.3 stroker right now and i need some torque specs to do it right.
I need torque specs for main cap , remember that im using 4g64 (2.4) crank,
are the torque specs the same what 4g63 crank is using ?
Im not sure here thats why im asking you guys
The crank was cutted at mashine shop and im using acl race bearings.
Pleasee replay fast because im in the garage now and im waiting for those numbers.
Thank you so much :)
^ LOL.
But yes as explained earlier, torque specs are the same, unless your using ARP hardware. Then it changes on weather or not your using moly lube or 30wt oil.
Okay so is this right guys ??
99gsx 7bolt block 4g64 crank
The Main bolts : 16 ft lbs + another 90-100° turn ??
Thank you.
and yeah hehe sorry i meant ''asap'' :D
anyone ??
  • Wanted 6 bolt NT water pipe
    • chrisman287
