tool much play in steering
red talon
54
Apr 23, 2011
billings, Montana
So I was having a little fun with the other night with my talon, it awd and did some donuts in it. And not very many maybe five. And now I it seems to me that I have a done more play in my steering. And also it pulls to the right now. I looked and I have nothing leaking and everything seems to be in place. But it still doing it. So can anyone help me ?
:aha:
That's what I'm thinking. But why would I have all that extra play in my steering wheel?
Yeah I'm not doing donuts any more
Could have a outer tie rod let go...if that were the case it would be way off...you need to pop the wheel off to find out. If a bushing goes it will have some play as well.
I would jack the car up and make sure your ball joint nuts are tight. Take a gander at the tie rod ones too while you are at it. About a month after I got an alignment, I started to notice that the steering drifted a bit back and forth depending on load/braking, etc. I crawled under the car and discovered that the ball joint nuts were backing off. Tightened them down and everything was nice and sturdy from then on.
