tob going out. question/help
newtodsm97gst
289
Oct 23, 2011
Lewisville, Texas
my tob is going out, because when I barely press the the clutch it make the woosshh sounds and goes away when i press the clutch all the way in. My question is can I replace just the TOB, because the clutch is less than 20k i believed. I haven't taken out the transmission yet because i'm not sure if I have to replace the clutch as well. i have 2600 act clutch and fidanza light weight flywheel. thanks.
If the clutch has low mileage than order an oem bearing from extremepsi or jnz tuning. The ones that come with act and most aftermarket clutches are junk.
thanks, ill check the clutch once i'm in it. ill replace it with oem tob.
while im at it should i get an LSD from extreme psi the $185 one.
