Tire fitment
gsxlover97
33
Feb 5, 2012
spokane valley, Washington
So I've been searching on here for the last few hours and just can't find a "will this fit thread" I just got a flat and need to replace quick. Have a set of 205/70/15 available will they fit my 2g gsx?
OP: what rim size and offset do you want to put these tires on?
15in rims will fit on a 2g GSX with stock brakes. I use 195/65/15 winter tires for Rallycross. My gravel tires are also 15s (most common rim size) and are likely as tall or taller than a 205/70/15.
Thank you all for the responses guess I should clarify a little more I have stock 17's but they are bad rims and all I have a set of 15" rims that's what I was asking if they would clear the stock 2g brakes up front. Not sure about width of rim or off set just know that they have correct bolt pattern
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
