Tips on changing rear wheel bearing 2G
No, those are just the mounts for the bearing/hub itself. With the spindle nut off the axle will come out with the BFH method described above.
As long as you keep the nut on the end of the axle you wont hurt anything. Try some PB blaster or Liquid Wrench.
My bearing went and I attempted to replace it I tried beating it with a BFH, then a puller, and I even torched it. Nothing ended up just changing the hub and the axle. The front was the same Had to buy the knuckle axle and hub. THey just rust weld together. Good luck but keep in mind most likely going to have to buy an axle
If you pull the knuckle off, you can take it to a bench grinder and grind the axle's hub down enough to let it pass through the knuckle with the hub still attached. I did that once. Not fun, but it saved the cost of a new knuckle.
When you do get them apart, add some good grease on both sets of splines, it will make removal much easier in the future.
One Wednesday, I did a wheel bearing that I replaced 3 years ago. Sticky tires are hard on bearings. I used 1600°F anti-seize on everything and the axle came out without even having to swing a hammer. It's good stuff.
