Changing wheel bearing
Mytrn2brn
145
Mar 11, 2006
buffalo, New York
Ok so i'm change the front passenger side wheel bearing on my 95 GSX. Anyone know what size the to lower ball joint nuts are? Dumb question, i know, but my manual doesn't say, nor the forums and the biggest wrench i have is a 19mm and it doesn't fit, :idontknow:so i have to go buy a wrench.
Thanks
I got a puller. But i have to separate the ball joint so i can get enough space to get the hub bolt off. any idea on the size of the ball joint nuts?
Thanks
Thanks, but the thing is Im not trying to remove the axle just the hub and my issue is that I don't have enough clearance to get the hub bolts out. However it does seem like you shouldn't have to undo the ball joints or the tie rod to get to the hub bolts. Shouldn't the axle be able to up back into the tranny just enough to remove the hub bolts.
Thanks
Ok guys I got all the hub bolts out without separating the ball joints, and i have my puller in place. So my dumb question this time is, does the brake dust shield hold the hub on in any way?
Ok forget the last question. I got the hub out of the spindle but its still holding on to the axle itself. I broken a bolt on my puller so Got run to the hardware store. I think I'm in the home stretch.
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
