Timing side Engine Mount Install
ncampos92562
365
Nov 23, 2009
Murrieta/Rivers, California
Long story short, the head came off and now it's back on getting put back together. And the engine mount is being a bi***. I got it off with a limited amount of cussing but I can't get this thing back on. I know I have to keep moving the engine up and down but when your given a 6 inch bolt with 4 inches of room, it is kind of hard to remember how to put it back in.
Anyone got an easier way? After this it's smooth sailing getting the car back together.
You can loosen the engine side of th mount to give it a little wiggle room. Other than that a lot of tilting, jacking, shaking and cussing should get the job done.
You can loosen the engine mount side of th mount to give it a little wiggle room. Other than that a lot of tilting, jacking, shaking and cussing should get the job done.
I agree with what black widow's advice. To loosen the engine and give a wiggle room. I also tried that one, and it just simple.
