Timing belt(Front) Engine mount.
BlueStream
Jan 3, 2005
Springfield, Missouri
The L shaped engine mount...i have it in the actuall mounting spot and on the studs comming up from the power steering pump. The damn rear bolts will not line up with the rear holes. What can i do to fix this. I have everything lined up and ive shimmied with it forever. HELP PLEASE!
Put a piece of wood on a jack and put the jack under the oil pan, and jack up the engine until they line up.
I had the same issue on the big horizontal bolt on my 2g. I found that slapping some arp lube (or motor oil) will help slip it in there.
