91Bomb
- 908
- 7
- Jul 15, 2003
US,
New Jersey
I just swapped my CAS and was wondering about a few things..
Chilton says before install to line up the thing that moves in the cas with a mark that's in there. Is that necessary since you're going to be moving CAS when you set timing so it's going to move off that mark anyway? Reason I'm asking is because I didn't check to see if it was lined up before I put it back on but after setting timing car seems to idle good.
Chilton says set timing 5 degrees tdc. Is that where a free modded 1g turbo guy running about 15 lbs boost wants to be
? Is 5 dtdc where you'll get the smoothest running engine though?
Which cylinder is # 1? When you open the hood is it the one all the way on the left or right? Somehow I forgot so I put the timing gun on each one and it looked to me like timing was the same on 1 and 4. Is that possible?
? Is 5 dtdc where you'll get the smoothest running engine though?Which cylinder is # 1? When you open the hood is it the one all the way on the left or right? Somehow I forgot so I put the timing gun on each one and it looked to me like timing was the same on 1 and 4. Is that possible?
