timing question (dowel pins)
djalogik
186
Feb 3, 2006
Austin, Texas
ok guys so my problem is that i bought a motor from someone and it did not have the timing belt on. So as Im getting to getting everything in time and checking all the marks i realize that my exhaust cam dowel pin is facing up while my other one is facing down. How can i fix this?
thanks
iI am replacing the cams anyways so i guess that when i do that i can take care of that?
That would be the easiest to do.
Once the old cams are out measure from the valve seat to the valve tip and make sure they are all the same height (so your sure none are bent). The turn the crank to TDC and install the new cams with the dowel pins at 12 o'clock.
