timing off?
93laserAWD
48
Sep 7, 2006
st. louis, Missouri
just replaced timing belt and i have a high idle, about 1600-2000 rpm. When i shut the car off it really shuts down hard and shutters the entire engine. could cam timing be off or base timing? i adjusted the cam angle sensor and the more i retard the higher the idle and the better the car runs, more i advance = lower idle and no power at all. thanks alot -ted
Take you timing belt cover and check all of the marks.
Sometimes when you put on the hydraulic tensioner, it can make keeping it lined up difficult.(at least it did for me)
the marks align at the middle ( where intake and exhasut cams are closest... but if i use a straight edge, all 4 marks do not align perfectly, they are off slightly
i can do that, i will check base timing and get back. a guy at my dads shop said it was timed right, but i dont know why the idle is so high. and i dont want to advance it too much on the cam sensor to melt a piston or sometihng
