timing off?
kevin keener
38
Sep 17, 2008
sparta, Tennessee
just put together an engine, it is jdm 6bolt bottom end with a 93 talon head. Timing marks are good. It is hard to start, and when it finally starts i have to play with the gas pedal to keep it running. I was wondering if the ignition timing could be off.
Yes you need an AFPR for the 255. Make sure you have the right plugs and gap (NGK BPR6ES at 0.028"). Do a BLT.
For timing questions, it's best to throw up pictures or there's no way for us to really tell if they marks are lined up.
Have you checked the ignition timing?
Engine Timing
Adjusted BISS?
1G BISS Adjustment
No check engine light on. changed out coil pack, and wires. Adjusted timing to 5 btdc, and BISS. Still runs sluggish and has a constant up and down idle. Will not rev no higher than 3000 rpm's. Anybody have some answers for me?OMG
