Timing marks for the crankshaft (any clear pics)?
Turbotalon25
98
Aug 30, 2008
Peoria, Illinois
I used the link.
Direct link: Timing Belt VFAQ
but it really dose not give a good pic of the timming marks for the crank shaft. Dose anybody have a clearer pic of the timming marks for the crank shaft?
I used the link.
If you look on the teeth of the gear, you should find a small circle indented into one tooth. That's your mark. If I get home before someone else posts a picture up, I'll grab a snapshot of my lineup for you.
Thank you it would really help me out I think I have it lined up right but I want to be right before I put my motor back in.
Ok I guess my problem is on the 2g (7bolt) crank I don't have the balance shafts and I have the cam gears lined up but its the crank I still have the crank angle sensor and plate were is the mark for the crank....? I'm sorry if I"m missing it on these pic's (they are alot more detail then the other one's I've seen). This just isn't my day......LOL
