Crankshaft sprocket timing marks?
eboy0
641
4
Jul 8, 2006
Chicago, Illinois
Can someone help me out with this? Today's been a pretty ongoing day...
I've got all the other timing marks set, or so it seems, except the crankshaft sprocket.. I can't find the timing marks, maybe I did, there's a couple of white lines on it and a notch along the outside rim.
Maybe the pictures will explain it?
Thanks
Little red circle, kinda hard to see. Is that the timing mark on the block that I need to align the sprocket to?
looks fine, make sure you replace whatever oil seal leaked all that oil or your new t-belt will be ruined in short order.. I'd suggest replacing all the seals on the front of the engine if you already aren't...
