Timing belt, Water Pump-700$cdn good price?
project95talon
49
Jun 14, 2004
Sudbury,
Ok so I go to local speed shop, have them check out the vibration from under my car...Turns out my timing belt needs replacing, water pump is leaking and my balencer belt? is causing the vibrating...does that make sense? Anyways they quoted me 700cdn funds for parts/install...is that a reasonable price?
700cdn aka = 565.832 USD
thanks guys...I just wanna cry
Parts alone will run you close to $300 US.. so that doesn't seem to be too bad of a price.
That price isn't to bad but I think that if you have access do it yourself. Not only will it be cheaper but you learn more about your car at the same time.
bet you that wasn't for real Mitsu parts... ;)
Good luck w/ that OEM supposed replacements.. :thumb:
alright thanks,....Quick question to everyone whos reading this...Would the balancer shaft cause an intermediate vibration and drop in rpm if one of the teeth quick at random times?
thanks
xxunkn0vvnxx said:
i just paid 270USD for labor & parts.. waterpump, accessory belts, timing and balance belts. im in FL :p
Where? I need to have mine changed. I'm at 74k miles, and it hasnt been changed yet.
