timing belt tensioner question
fatherbubble
273
Jun 20, 2007
baton rouge, Louisiana
Well I reviewed my question and found nothing on here to help out so now I'm asking. On the timing belt tensioner I know its possible to tighten it the wrong way. Can you actually tighten the belt like that? If you can or cant does anyone have any pics up close of it on there engine? I have an issue with my car in the shop. They said the guy that replaced the head tighten the tensioner the wrong way. Causing the belt to get damaged an the water pump too. They also said that the oil pump gearing is crap from it being like that. I know this when I got the car I checked the belt to see how tight it was. I couldnt make the belt sag by pushing between the cams so It seemed good to me. As it had tension.
From looking at vfaq it seems that if you try to tighten it the wrong way it would just get looser. So I'm stumped here please help.
So, do you think if you loosen the timing belt up all the way that the pulley would rub on the water pump? If so on that do you think that with the pulley and crank would be working against each other? Like say the pulley slowly moving the belt and the crank pushing the belt hard to it?
It was said that the tensioner was loosen all the way on my car. The belt when I felt it was like a board straight and hard to push.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
