ReliantK
- 0
- Jan 29, 2005
clifton park,
New York
Friend has a 1990 Mitsubishi Eclipse GSX, the car died and we checked the timing belt and found it was shredded with only like 1/4" width of the belt holding the cam gears still timed correctly together, but the timing belt was all stripped where it goes on the crankshaft pulley. So the crank was spinning and the cam gears not moving. We bought a new belt and are attempting to put it back together to see if the valves are bent.
My first question is: Because the cam gears are still aligned, does that mean the valves won't be bent?
Second question is: We put the new belt on but didn't replace the tensioner yet, we aligned everything up the way it should be, cams, crank, oil pump, etc and turned the motor over a few times with a wrench on the crank and everything stays aligned, everything rotates like normal and we could hear the motor had compression when turning it but when it gets to a certain point the belt becomes loose on top of the cam gears in between them then tightens back up, I'm assuming the car needs a new timing belt tensioner?
Third question: If any of the valves were bent, would the cam gears still turn? I would think the cams would lock up but wasn't sure. Any tell-tale signs to look for while we still have it all apart? Thanks ahead of time!
Plain and simple. If you said the crank turned with out the synchronous drive belt (timing belt) then yeah, you have some pretty unhappy valves and a very very upset wallet!
Take off the head and inspect.
