*Timing Belt- now coolant light..*
Sinclair159
179
7
Apr 12, 2005
Taylor, Michigan
Just got done doing my timing belt on my 1g.... everything went perfect.. car runs like a dream again.. only problem is now my coolant light is on.. or radiator light or whatever i think it is... both electrical connections are pluged in on the radiator.. that was the only think i could think of... any one else have a clue why this light would be on ??:confused:
Is your coolant low? If you don't have enough coolant in the overflow the light will come on.
Sinclair159 said:
ohhh i didnt know that then overflow bottle had to be filled.. i just filled the coolant from the opening next to the valve cover..
Not FULL just maybe 1/4 or 1/2 way.
There is a low coolant sensor in the bottom of the overflow bottle. Just add some coolant to the overflow and see if the light goes out.
