Timing Belt from Autozone
find out what brand of belt that autozone sells and do a search to find out what other people think of that brand. i know it auto zone but they may sell good belts like gates
:talon: :rocks:
Change your auto tensioner while you are in there. Most belt failures are due to the fact the tensioner has just given out and can't take up the slack. That is as important as which belt if not more important. Do use the best grade of belt you can get. Like most others, I use the Gates belt. You probably will find that most other retail outlets use Gates belts under a "house brand" name. Just make sure you set it right because you get only one chance to get it right.
Good Luck
We run nothing but Autozone belts in our 3 DSM's.....unless you're in the high horsepower zone (700+) they should be sufficient. By the way, Autozone sells Gates belts.
