Tie Rod End boot Install
I bought the energy suspension kit for my awd and it came with tie rod end boots here is the install and on it.
1. Take your rim/tire off
2. Take your brakes and rotor off (optional)
3. then use a dikes to pull the pin off the tie rod end boot nut
4. Use a 17mm socket to take the nut off
5. Then I used a ball joint separater and separated the rod
6. Then i used a gear puller to take the boot off
7. cleaned the rod out really well with parts cleaner
8. Then put lots of grease back in the boot and put it all back together.
a lot cheaper in some cases if you boot is just worn out then buying the hole tie rod end and the es boot will last lot longer then any stock boot.
