Ticking sound
im having problems with my sound on my computor, but ill bet your talking about the lifter tick our cars are notorious for. There are many threads about this with video clips - check them out maybe they can help. If its the lifters you can change to the 3g revised lifters and the tick will go away.
yes you need the hose, thats like running without a air filter, also there car is getting more or less air than it thinks it is, or you could get a cap to put on the intake pipe.
Yea im looking for a cap but where can i get one that size
This is to dsmrollerz90
please let me know the 5 things that need to be fixed ### i had my friend put it together ### i was vaca and he made it seem like it was perfect so let me know !!!
Thank you
If your talking about capping where the bov should be recirculated I have some news for you..You cant just cap it, You really need to get it back to recirculating..If you want to run a vented bov, you need to go through the tech articles and find out how to do it properly..I'm not going to spoon feed it to you..
Like stated before tho, sounds like lifter tick..3g lifters will fix that right up..
Is this Something maditory to get repaired or can i hold off on it for a little and does anyone know the price rage to get it repaired
Its best to get it fixed as soon as possible as there's slack in the adjusters that's why you hear the ticking noise and if it goes on too long it could damage your valves.
Have you tried just changing your filter to a OEM one? Some times this works too but, its best to just upgrade to 3g lifters anyways.
3g lifters can be had for less than 100 bucks and free to install if you do it.
Not sure how much a shop would charge to do it.
Theirs a tech guide here that shows a step by step how to on changing your lifters.
Here is a good place to get 3g lifters.
http://www.store.partsdinosaur.com/4G63_4G63T_Hydraulic_Lash_Adjusters.html
okk Thank you ill get it done asap and for now its not registered so i dont drive i just start it every morning can doing this still cause some type of damage
wow lifter are that cheap thanks again Bro
how many lifters do i need ??
4G63T Mitsubishi Lash Adjusters
Thank you bro
ok so i got the lifters and before i got them installed my mechanic said its not the lifters the noise is coming from the injecters and that it means that the injectoers are breathing is this true ???
Injector ticks is normal, there just solenoids that open and close. I wouldn't worry about it.
