TiAL to much???????
DSM1.8T
31
May 22, 2003
Rochester Hills, Michigan
I love the way the tial sounds but is it a bit to much for me? I have a 1G with a 14b running about 15lbs. what are my other options for a sound like the tial?
The sound of the Tial is unique. I went from the SSQV with my side mount to the tial on my FMIC with translator. Alot of my friends like the sound of mine and they have the 1G, greddy, some loud RFL thing, and a Apex. No two sound the same. But why buy a BOV for how it sounds? does it hold boost, then it works. Out of the 2 I have owned, the SSQV was the loudest by far (vented occasionally) but it pissed off so many normal people. I had one guy swerve across a lane of traffic when I blew off once. now things are more calm with the tial, but the dump tube ruins that idea after boost.
So as long as the one you have works just stick with it, when it finally leaks, then upgrade. But now you can use that money for something else looking at your profile, you do not have intake listed, maybe use this money for that? I assume you have a Boost gauge (even though it didnt say) since you have a boost controller. Just my thoughts.
Nothing else sounds like the tial, I went to the tial on my setup and id never have a diffrent bov again, I absolutely love this bov, The only bad thing about it is it will tend to flutter at around 10-15 psi, So im not absolutely sure if it will work out on your car. Since your running such a small amount of boost.
I love the flutter though, and i'll be at 15lbs when the new clutch goes in. Cant you get it with different springs for less boost like a 4,7,10?
