Gooberlog
- 2,482
- 5
- Dec 30, 2002
Westminster,
Maryland
No coment...the motor is all stock. Naturaly Asspriated no NoS
Originally posted by WarpathDSM
I was just wondering if 22 psi was to high to run. My main concern is my head gasket. My mods are up to date in my profile but it's a big 16 ported and clipped incase your to lazy to go look. thanks
Originally posted by UNFORGIVEN GSX
Please don't start this Domestic vs. Import bullsh*t.![]()
Both cars have their pluses and minuses. Have you ever driven an LS1 or a V-8? I must admit, the torque is utterly intoxicating. I dislike having to wait for power with a turbo inline four and it only gets worse with the bigger turbos. However, when the turbo kicks in it is nice.
I still believe that it is not that smart to run high boost all the time without upgrading your head bolts to ARP studs. This will make sure that the head doesn't start floating as the boost pressure ADDS to the pressure of the explosions in the cylinders on the head.
As always, correct fuel management is essential to saving your engine.
Rob
Actually I had a supercharged 4.6 with a 99 head swap that made 402 HP to the wheels. Have you driven a well prepped dsm with a large turbo an supporting mods?Both cars have their pluses and minuses. Have you ever driven an LS1 or a V-8?
Originally posted by jdmawd
Unreal explained how head lifting and head gaskest failure has zero to do with boost pressure i know a guy that ran his l3r at 30 psi on the stock studs. what you *beleive is not fact* example i think the sky is purple.
Originally posted by Phoenix_RsX
hahahahahahahahaha :laugh:
That is not true! There are alot of people that run 20 to 23psi on a Big 16g. Every car is different, so some may be able to run that much boost and some may not be able to run that much boost. Look at the times list over at DSMTALK.com in the racing forums under times with upgraded turbos and you will see. I run 21psi on my FP ported Big28 with no problems at all. You could probably run more boost than 18psi when you upgrade to a fmic. I ran 18psi on my Big28 on the stock smic with no problems. A fmic makes a big difference. 18psi is nothing on a Big 16g. Your turbo has plenty left in it.Originally posted by Phoenix_RsX
On a B16G, yes. the b 16G even if it is ported and clipped is only made to hold 18 max......even if it does run at 22, I'm pretty damn sure you aren't going to get much more.....if any more power out of it....and you'll be killing the turbo way before it's time.....you want 22 psi? convert to a 20G or get a turbo that can hold it with out killing itself, the 16 wasn't made for that man.
It doesn't have that much more topend if any over the Big28. Look at some of the trap speeds on the times list over at DSMTALK.com in the racing forums for upgraded turbos and compare, and remember the Big28 has only been out for a little over a year now as compared to the Big 16g that has been out for years. Big 16g= 550cfms, Big28= 550cfms. Anyways... back to the topic just do some logging to see if you can indeed run that much boost. Logging and egt's are the only way to know for sure.Originally posted by umiami80
Well a BIG 16G has more topend then a BIG T-28, but the T-28 has better spoolup and mide range, but all out the Big 16G moves more air so that is probably why.
