Tial External Wastegate not opening after turbo swap
4gfun
Supporting VIP
2,009
56
Dec 10, 2007
Ask Me, Virginia
I switched from a s16g to an e316g.
The turbo builds boost fine, but all I hear now is my blow off valve at higher boost.
I have everything set up as follows:
Straight part of the NXS MBC to J-pipe. Angled part of the MBC to the side port of the TIAL External Wastegate. Not really in the mood to have to remove my radiator/fans/etc and all my fresh coolant to mess with the External Wastegate.
What gives?
Thanks!
UPDATE
It seems that the EWG is just fine. I ran it directly to the J-pipe. It opens up but it is just much more quiet now.
i was gonna say if your not overboosting than the biatch is opening up, but i saw you figured it out. When I switched my turbo setup and piping it quitened down my wastegate too... more direct flow i guess!
