2G Tial Bov on Stock 2g Eclipse GSX
Trison21
May 13, 2016
Arizona, Arizona
I just received a Tial 50MM Q Blowoff Valve from a buddy of mine. http://www.extremepsi.com/store/product.php?productid=21495&cat=390&page=1
It is not recirculated so I would need to buy a Tial Q Recir Blowoff Valve "bottom portion" with Re-circulation fitting correct? With Re-circulation Size 1.5" or 38mm ? Would this fit the stock intercooler piping? http://www.extremepsi.com/store/product.php?productid=24254&cat=390&page=1
I believe I also need this, Is this correct? http://www.extremepsi.com/store/product.php?productid=25694&cat=390&page=1
Thanks for the help
The re-circulation size you're asking about should be just a tad bit smaller than the re-circulation hose/tube you are using to re-circulate the air back to the turbo intake pipe.
OR
The re-circulation size you're asking about should be close to the same size as the turbo intake re-circulation tube/hole. Not the hose/tube.
Given that your car is completely stock (assuming your profile is correct), I would recommend selling that BOV since it is overkill for a car with no modifications, and buying a cheaper crushed 1g bov or something of the sort, and using the money to upgrade other areas of the car. Besides, you're setting yourself for some additional expenses just to make that BOV work.
