Small hole in 1g BOV - Installing 1g BOV on 2g eclipse gsx
2gsx2tame
May 9, 2003
Hello, after browsing and searching around for over an hour, I've come to the conclusion that I just need to ask for help. I built a boost leak tester and found a few big leaks - one of which was the stock bov (common problem it seems). I bought a 1g bov and also upgrading the intake piping. Now I am about to install the bov to the new pipe but... that small hole will be covered by the flange on the pipe. I read an article that tells me it is some kind of quick release. http://www.dsmtuners.com/threads/whats-the-small-hole-on-the-under-side-of-the-1g-bov-for.310966/ I am running stock boost with the stock turbo and not looking to modify the bov for extra boost. Will this work or is modifying the bov a requirement (such as drilling a gouge from the center to the small hole)? Please see photo here -- https://imgur.com/a/C9aM6
Thanks for any help!
