throwout bearing question
andizzle
Nov 28, 2010
zanesville, Ohio
i did some searching but didnt really help...the bearing makes a loud noise when the clutch is only out so i know its muffed up...but the weird thing is it goes away after the car warms up some...5th gear isnt there also..it goes in but doesnt grab (u can hear it trying) my local dsm guys in town say the throwout bearing will cause this but i have never heard of a throw out keeping it from 5th...any ideas before i start tranny shopping..its also a 420a car if that helps
sound like a clutch or a trans problem. I'm leaning toward a broke trans.
thats what im leaning towards, every other gear works great so im going to just rock it out till i pick up my new trans and clutch, figured i couldnt get lucky with a 30 dollar part fixing it LOL
1. As much as I like Quagmyre, I figure I will give you a heads up before a mod says something.
"Your Avatar is displayed under your username whenever you post in the forums. Your Avatar must contain a photo that clearly depicts your DSM, or if you don't own a DSM, the vehicle you own. If your Avatar does not comply with the Avatar rules it will be removed."
2. Is you clutch adjusted properly?
