throttle slightly sticking
nytescion
602
Jun 25, 2007
Woodbridge, Virginia
My throttle body seems to be sticking when I come to a red light or stop sign. I've confirmed this using my maftll Top voltage. When coming to a stop the voltage reads
60. Now when I flick the Throttle it closes all the way the volts read. 50 and my idle comes back down to regular. My question is how do I fix this.
Take off the TB elbow and clean the throttle plate with some kind of solvent/intake cleaner etc. There is probably just some buildup on the throttle plate which is holding it open just a little bit. Spray some cleaner in there while working the throttle plate and then wipe it clean with a rag. Repeat until the throttle plate is clean and works smoothly.:thumb:
EDIT: first response didn't show up on my page! Sorry for similar info! : (
Do you still have the cruise control box installed? If so that is the culprit. Open it up, clean it out and lube it up.
If no cruise - the TB butterfly needs to be loosened up. Also, check to see if your cable is binding anywhere to cause it to stay tight. Lastly, your TPS is sticking. You can see its range of travel when it is unbolted.
Good luck man!!
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
