spyderdrifter
- 5,426
- 860
- Jul 11, 2009
Somewhere in,
Colorado
I think the shaft seals in my 2G throttle body are bad since theres a loud air leak in the location on the TB. Ive never replaced those seals on any TB, but Ive read that it can be a pain, and that breaking them on first try is likely, sadly. I already have a set of shaft seals that I bought some time ago, and I want to install them. But in the meantime, I figured Id put my 1G TB on as a temporary replacement. That being said, I have a few questions about swapping them.
First, since the 1G TPS has 3 wires and the 2G has 4, should I just swap my 2G TPS onto it?
Second, what is the piece Ive circled in red, and what connects to it? Does it need to be connected on my setup (6 bolt block, 2G head)?
Third, the 1G TB has 4 vac nipples, 2G has 3. Im sure I just need to extend them all so they hook up. The P, and E nipples are obvious, but how do I hook up the A1, and A2 nipples when the 2G TB only has A?
