1G Thoughts on moving radiator fans to other side of radiator?
Vegas Smith
5,193
3,155
Dec 2, 2002
Houston, Texas
Hello, I couldn't find any information on moving my slim mishimoto fans to the intercooler side of my mishioto radiator. I've heard of someone doing it. I love to save space so I was wondering if anyone has done this and what are the pros and cons of doing it. I currently run a 16g setup but will be moving t3/hx35 soon. Thanks.
I did it on my car with no issues. I've put 2 flex-a-lite 12" in front of my rad.
You can but not with the shroud.
I managed to do mine but the shroud is plastic which the mishimlto is aluminum so it makes it even harder to install.
Im runing 2 12s (#490 FAl ).
Here is the mod i did to the shroud (cut to fit),
The third pic is my old set up (2 10's) they were not enought for the heat in fresno,.
When i was in the bay area there were fine, but i moved to fresno where is hatter and there were on at all tie trying to keep up but some times my temp were a bit higher then my liky, so i upgrade to 12's.
The last pic is my current set up.
I have one push and one pull no issues! Plenty here use push sryle fans but rhe pullers are optimal. Once the car reaches certain speeds the fans become irrelavent.
