Those wondering about the limits of an upgraded SMIC
VRMAN
634
3
Apr 8, 2003
Daygo, California
I know some people out there are looking to run bigger turbos on a sleeper-type setup. I have an SCM32 (54 trim) with the supporting mods listed in my profile. I was curious how the Dejon Tool Super-sidemount would hold up cooling higher boost without heatsoaking. They say it is rated to 400hp as well, I called Dave at dejontool and he said that the upgraded sidemounts can effieciently cool the 50 trim variants up to 18-19psi. But since I plan on running more along the lines of 20-22psi I also rigged up a C02 sprayer to combat heatsoak.
My reasoning for the Supersidemount was sleeper status and also that I had JUST paid full pop for my IC pipes when I had an 18G on there and switched turbos but wanted to keep my SMIC location.
I dyno'd my car the other week and put down 305whp/300tq completely untuned. Just all the parts bolted up and gas added. After the initial pull I checked the sidemount and it was still room temperature and no timing was pulled. After the second pull (2 minutes after the first) I checked the IC again and it was hot to the touch, so it only took 2 pulls to heatsoak the super-sidemount on my PTE 54trim. Now, this was at 21psi, which is what I am aiming to run on the street. With the boost set at 18 psi, it was pulling fine with no heatsoak for 5 and 6 pulls. So I think the Supersidemount and HRC sidemount are good on 50trims until 18-19psi. 20+ psi required that I spray the IC with water to displace some heat, so if you plan on running over 20psi on a large turbo with a SMIC, plan to rig up some sort of C02 or water sprayer on the IC.
Hope this helps anyone curious about running a big turbo on an upgraded sidemount. It is doable but for serious boost, you'll need a little help.
herostar said:
Are you planning on tuning it and then dynoing your car again? I'm interested to see how much you can get out of that SMIC.
Yes I am. When I work out the few bugs I have then I'll be hitting up the dyno again. I plan on running 110 octane and am going to shoot for a 25psi pull and see if I can't put down 375whp. I'll have a water sprayer firing on the SMIC the whole pull. It'll be few weeks but I'll keep you updated. I love the idea of a big SMIC but it does have its limits but they are higher then I think the average person gives them credit for.
Thanks very much for putting up a review of this intercooler. I have the same one on my wishlist for my Big 16G and if it'll handle your 54 Trim at 18 psi, then I know it would be fine for my turbo at 20 psi on pump gas. Coupled with the lower hardipe kit, this is a real winner.
Here's to stealth and thanks again for posting your findings.
Andy
Isn't there an airflow factor involved here to. I know the Supra SMIC ect. can flow around 400cfm compared to a FMIC which is normally double that. Isn't there an airflow loss here which also contributes to hp loss.
This is kind of the same path I plan an taking, but with a few exceptions. For one, I'm going to stick with the stock SMIC as long as I possibly can. To combat knock and heatsoak, I will have a dual stage (two nozzle) water/alky injection installed - smaller nozzle pre-intercooler for heatsoak and the other nozzle just before the throttle body. I think this would net some pretty nice numbers considering the airflow restriction of the stock SMIC.
Keep us updated with your results!
One thing to remember - the fans that they use at a dyno give you no where near the airflow you would get if you were moving. A SMIC will get heatsoaked quickly when standing still in front of fans, but do a few pulls on the street and try the same thing. Chances are that the IC will be quite a bit cooler than it was at the dyno.
i'm running the stock sidemount on my 14b/272s setup, dynoed 289whp/304ft-lbs. On the street during a 3rd gear pull, I'll see charge temps of around 150-200F. On the dyno, I was seeing 225-250F!! Surprisingly, on the pulls where it hit 225, there was no knock, and on the pull where it hit 240+, there was some knock above 5k but the dyno curve looked identical. I'm curious to see how this translates at the track, since I have yet to do a full pull through all the gears. :rocks:
All good info. I also took out the fog light so there is direct air to the S-SMIC, you can see it through the bumper duct.
I didn't realize the fans didn't provide adequate air, thats good to know on the street it'll be slightly cooler.
I'll update this thread when new information comes in. Anyone else running a big sidemount post your thoughts/reviews in here.
I'd like to know how long it takes for the IC to cool back down at idle, or maybe a fast idle. Unboosted intake has to suck the heat back out of it pretty quickly, from running cool air through the inside of it.
I was running the Supra Sidemount on my 50 trim. It worked well unless it was pretty hot out (>80deg) or I did 3 or more pulls in a row. At the track, it tended to heatsoak at the top of 3rd and into 4th gear. I was able to get an 12.3@111 with it though.
I haven't experienced any of these problems on my frount mount however. ;)
Another update for you guys, I had the car tuned and boost leaks fixed as well. This time on the dynojet I put down 309whp but the big difference being that this time it was at 20psi and PUMP GAS 91 octane. So with some good tuning on the AFC I was able to put down nearly the same amount of power as the last trip to the dyno but with 9 less octane points then the previous trip. I had planned to go big on the dyno and see what max numbers I could get out of the setup but decided to go for real world power since the car is a daily driver and did it on pump gas. Also, we did 5 straight pulls and the SMIC got warm but not hot like it did when I went the previous time. Boost was only down 1 psi so that was kind of confusing but none the less the SMIC held its own. Hopefully I'll shoot for the big numbers next time. Still planning my 110 octane + 25psi trip to the dyno but I'm wondering how the stock shortblock with 125k miles is going to fair.....
